ok here it goes, it dosent look like its a head gasket situation, since they are brand new. When i turn on my car in the morning i will drive it for like 2 mins then the gauge will climb up to the middle on NORM which is a good normal temp but then it will move back down to the N what is this trapped air???? and how can i get it out????? by the way i have no coolant in oil, i have no water leaks and i have no white smoke coming out my exhaust. thanks for the help.
CamellionCat
Sticky t-stat? It has happened on every vehicle that I've driven except my work truck which is an 02. I think its probably normal.
yeah try a new t-stat and bleed the coolant system. When you replace the t-stat start the car, and fill the radiator until it bubbles over a bit.
-Thomas
how do i bleed the cooling system?
CamellionCat
