hi
im having a little temp problem
the temp gauge is going from n then quickly to m then i hear the fan turning on then drop back to n very fast
im just wondering if its anything bad
thx
You might have some air in the system. Where is the fluid level sitting in your
overflow resevoir? Have you done any work to your cooling system recently.
How long has this been happening, when did it start?
Chris...................
hum i never did any work the the cooling system... and its been doing that for almost a month.
and the fluid level is good
so i really dont know
thx for the reply
thx for the reply
Monitor the level of your coolent when the engine is cold and later when the engine
is hot. What differance do you see. When cold the level should not be lower than
min. When hot the level should be somewhere between min and max. You may be
just a bit low on coolent. Have you added any lately
Post your findings.
Chris...........................
