Just a heads up for you all -- I did a "search" here this morning, trying to find the location of the sending unit for my dashboard temperature gague, and seemed to find about everything but. I ended up going to a local NAPA and buying what they said was the replacement, but it was not like what I thought was the unit in my car. FYI: my gague was reading dead center all the time, from start up to shut down, but no other symptoms of engine temperature problems were evident, so I figured it could be the sender / sensor. After bringing the wrong part back to NAPA, the counter man called his supplier, and they gave him the correct number, and I got a part that matched one of those under my hood. Funny thing was, it was what I thought was the sender to the computer, not the sender for the gague -- I was wrong!
Here's the deal: on my '97, the dash gauge sending unit is on the top of the intake crossover, on the PASSENGER side, to the left of the alternator. The computer sending unit is on the backside of the thermostat housing unit, which is on the driver's side, to the right of the alternator. Both senders have plastic "sockets" integrated with their top, NOT a simple brass threaded stud to which you screw a wire and a nut. The Temp gauge sending unit is GREEN, the computer sender is GRAY. Both have two leads, and they are not interchangeable, the plugs on the wires and sockets on the senders are different.
I hope that may help someone.... It would have helped me if I could have found it this morning!!
BTW, when I got the right part, I pulled the plug from the engine, attached it to the UNinstalled sender right there in the NAPA parking lot, and started the engine -- the gauge went right to "Cold" as it should have: Success!! I will install it when the engine cools, this afternoon sometime.
:thumbsup:
:thumbsup:
