95 LX 4.6L
My belt tensioner is moving up and down quickly at idle, and there is a squeak, like twice per second on a regular basis.
When I remove tension (on the tensioner assembly) with the car running, it gets quieter. The pulley on the tensioner doesn't seem to be loose, but the idler has a little side play. Not sure which is squeaking out of the two pulleys.
The belt is newer. Seems to be a lot of tension with the tensioner, so not sure why all this movement. Any suggestions as what to replace first? I don't want to replace tensioner and both pulleys if I don't have to, but will do it if I don't hear anything back soon. LOL! (off to buy some AC refrigerant)
Mark
Mark
