Here are some pics of my 95.
I need to take some more of my 73.
Like this one.cb95sc said:Nick it is a dry cell battery approximately 20 lbs sold with a Holley Racing battery, but I think it was made by Oddesy. It is about 5 years old sits more than it is used and it always works well. It easily starts my 12.5 to 1 big block and holds up to dual electric fans, Aeromotive fuel pump, MSD ignition, but if I ever have to replace it I will most likely buy one of the Dyna Batt that is smaller and only around 14 lbs.
Charles
cb95sc said:Here is a couple of pictures of my junk! Of course these were taken prior to the 96-97 headlight swap and as always there are more changes on the way.
Charles
Yes they are and they are 18x8.5 with 6.125 back spacing. They are intended to be used on an 2005 and later Stang. I am running 245/40/18 in front and 295/35/18 in the rear without any issues, but I am not sure how they would work out on your seven. Not a bad wheel for daily driving but I am looking into something different for the track to try and lighten it up a bit, but with the Brembos up front it is hard to find a wheel that will fit.mark007 said:i didnt notice the first time i posted to this pic, but are those the wheels from maximum motorsports. i believe their called the maxim. if so are they the 18x8 or 9. and what kinda backspacing is it at now. would like to do a set of those for my car. and have them widened to a 18x11. i'm thinking 325 or 33r on the rear would look killa.![]()
charles hope you dont mind i posted the pics you have up on the corral a few days ago. someone was asking to see the wheels you have on a fox body but no one had any. so i told them about yours and they wanted to see. so i posted them. again hope you dont mind if you do i'll take 'em down. also good to hear about the new times you're running.cb95sc said:Yes they are and they are 18x8.5 with 6.125 back spacing. They are intended to be used on an 2005 and later Stang. I am running 245/40/18 in front and 295/35/18 in the rear without any issues, but I am not sure how they would work out on your seven. Not a bad wheel for daily driving but I am looking into something different for the track to try and lighten it up a bit, but with the Brembos up front it is hard to find a wheel that will fit.
Charles
