61 - 78 of 78 Posts
So add a power filter/conditioner?? Are those things ever worth a crap? I always wondered if they were snake oil.
Discussion Starter #62
Hahaha guys, thanks for all the tips.
The switches are already dimmers - Lutron Toggler C.L Dimmer Switch for Dimmable LED, Halogen and Incandescent Bulbs, Single-Pole or 3-Way, Light Almond-TGCL-153PH-LA - The Home Depot are what I used. The wall sconces don't make any noise when dimmed, but the recessed lights do (the lights themselves buzz and get louder when dimmed - not the speakers). Those don't get used if we're watching anything. I went a little out of my way to make sure the 120V feeds for the lights were nowhere near the speaker wire. The RS and RSR speakers do cross by where the high voltage lines run where they go up into the ceiling but they don't run parallel and they are several inches from physical contact - I have never noticed any noise from the speakers with any of the lights on or off.
I will speak with the wife about painting the baseboards the same color as the ceiling. I don't have enough of that paint left however to do much of anything aside from touch ups (it was a VERY close 1 gallon to put 2 coats on the ceiling) so I wouldn't be able to get more paint until the state lifts the stay-at-home lockdown for non-essential travel. Plus I kind of like the way it looks in white with the contrast, but I do admit I need to consider the application of the room into account a little more with the colors! I'm still not sure if I'll change how I have the door, but I'll see what she says on that as well. In the end I would be happy with it either way I think.
I got 30/40 of the remaining trimpieces I have here painted last night. I'm waiting another day for them to cure before I cut and install them. I was going to start by putting the baseboards in the theater but I guess with this question of color, it makes sense to start in another room until that's decided.
A good one is wonderful. The cheap crap is cheap crap.
Source: Electronics technician who's seen the waveforms in and out.
Also, note: The best ones I've seen ... hummed.
Dimmers are made from a device called a Triac.
They work by turning on the ac waveform for part of a cycle; 50% on makes a nice 180Hz noise on all the ac lines.
Audio lines ran nearby can pick it up, and amplify it.
If you can't hear it, it's fine.
If you hear a bzzz, hmm, bzz, bzzz working it's way thru your audio, that's the source. :)
Discussion Starter #65
After an extended period of doing, well, nothing, I finally got some energy to move on towards the finish line the last few days.
I got the last of the trim installed tonight. Baseboards, remaining door casings, the toe kicks under the cabinets/bookshelves... For all intents and purposes the real construction is done. :D
I'll post a few pics or something in a day or two, after I've had a chance to clean up all the remaining trash/tools etc. down there.
My list of what's left to do is pretty short, all things considered.
1) Fill nail holes
2) Touch-up paint
3) Reinforce counter mount
4) Covering for the top of the sump pump box
-- can do after inspection --
5) Install wire shelves in closets:
a) base of stairs
b) bathroom
c) walk-in
6) Opt. solid shelves in foyer:
a) above cold air return near den door
b) on wall against bathroom
7) cabinets and countertop in workshop
So they convert the line noise into real noise? Nice!
1) Fill nail holes
2) Touch-up paint
a) base of stairs
b) bathroom
c) walk-in
What was the verdict on color matching the door to the walls? I think the look is great in my own Home theater.
Discussion Starter #68
We opted to leave it with the contrasting white. It's not at all distracting while we're watching films (it probably helps because it's completely light controlled) and it helps the room feel a little less like a cave, which we both like. I do definitely understand your point of view though.
Discussion Starter #69
OK, here are some pics of "done". Still need to set up furniture and stuff, but that comes after the inspection this week - and as finances permit. I also spent 15 minutes walking through, describing things - for those with time/interest to listen to my monologue.
38410
38412
38413
38415
38417
38418
38419
38421
Great work! And wow! What a lot of work. you did an amazing job.
Discussion Starter #71
Hopefully you can make it up here for the eclipse in a few years (and that it's not cloudy!). You'll have to start a thread for the finishing of your theater next. :)
Will do! Right now I'm looking at a car audio build for the Tbird!
Discussion Starter #73
I picked up some shelving and set it up downstairs this weekend. Most of what I am doing now revolves around getting the gaming room/den set up, so today I got the CRT set up with all the CRT-era consoles and titles. I also moved the old PC titles for when I can get them set up. I have my eyes on a couple PC tables for later which will go on the other side of the room. Fortuitously, the TV cabinet I picked up off Craigslist right after we moved in 2 years ago is a great match to the floor!
With the theater currently holding the reclining loveseat hostage until the theater seats can be bought, I will need to come up with something for the gaming room that isn't quite as tacky as folding lawn chairs. :ROFLMAO:
38456
38457
Yeah, I was a Nintendo kid growing up. :)
  • Like
Reactions: CDsDontBurn
I need to find you one of the gold connectors I have; you'd actually use it. :)
I bought 20 of those in 1993, and sold almost all of them in a year.
Everything is looking Great!
Any teething issues?
What was the first movie you watched?
Discussion Starter #75
Nope, everything works exactly how I intended it to! I do have (on the long list) plans to build and hang a few acoustical panels in the room to get the reverb down even more, but it's acceptable as-is; with the extra chairs going in I may not need it (I will measure it before I add any more dampening materials)
Oh gosh... I think the first thing I watched was Endgame. The "official" first watching party (whenever that happens) I think will be LoTR.
  • Like
Reactions: Grog6
I need to watch those again; the last time I watched them all together was when I was down with the flu a few years back.
In a fever, I watched LotR, Aliens Box Set, and The Derek Flint Collection.
Unfortunately, I seem to remember Flint shooting Sauron, and blowing up his island.
And Gollum busting out of someones chest and grabbing the ring.
Like I said, need to watch those again, lol.
Discussion Starter #77
I've seen them so many times I can probably map out the sequence of events, scene for scene, from memory. Not that I'd want to. Even for films like that though, seeing them in the theater is such a different experience that makes it worth re-watching anything. :)
I've been slowly accumulating Blu-rays of titles I've had DVDs of for a while, but something I've heard you mention in the past is how the Matrix looks on DVD vs. Blu-ray. I think I'll leave my DVDs of those alone.
I was disappointed by the Matrix Blu-ray; I could see every effect, and the CGI Neo in some of the fight scenes ruined it for me.
The DVD is perfect; I've had it since 99, and never noticed anything different than the Theater.
  • Like
Reactions: Trunk Monkey
61 - 78 of 78 Posts
