1 - 2 of 2 Posts
There was a slight coolant leak and it seemed to be coming from the t-stat and there was coolant in the ridges with the plugs. We just replaced the thermostat and o-ring without flushing the system. We pulled off the upper hose, let the coolant leak out, replaced the t-stat, put o-ring on top and torqued it under 20ft lbs. The car was started and it started weeping out the front of the plastic above the water neck. So, i put in the old t-stat and gasket and it did the same thing. From what i can tell, there are no cracks whatsoever. The dealer did say that the t-stat is bad a while back. My question is, if the coolant isnt drained, will it cause too much pressure? Or is there something else wrong? Need help ASAP, thanks.
Adam
yeah well thanks for the help guys, the problem is the intake. Hairline crack starting at base of water neck, doesn't allow tstat and o ring to seal off the hole due to the crack giving to pressure.
This intake was replaced under the recall in 99, and 7 year coverage ended march 03 for me. I would only have been covered till 00 with a 1yr war. on that "new POS" intake.
I am thorougly pissed off at Ford, for making the ****tiest engine possible, then hiring retarded chimpanzees to design the intake, exhaust, etc.
I'll be on the phone with ford reagarding this BS. I really wish I was behind the seat of a 93 MN12 with a 5L pushrod engine right now.
1 - 2 of 2 Posts
