1 - 2 of 2 Posts
1990 SC
i have another problem...... now my brand new thermostat and thermostat gasket is leaking like crazy. I was filling the radiator and it came out of the bottom of the tstat housing. It was perfectly fine before. I tried wiggling it around to get it to sit right and retightened it a bunch of times but to no avail. I had absolutley no problem with it before hand. so its not warped. Is there a trick to lining it all up or something?
any suggestions? maybe silicone everything togetheer then bolt it on
SC UL8R1990 said:
1990 SC
make sure everything sits and lines up perfectly. did you use rtv gasket sealant? you may need to get a new gasket. get one that has an adhesive backing and attach it to the housing, add sealant and put it back together. good luck.
1 - 2 of 2 Posts
