1 - 20 of 34 Posts
The 4.6 is a very solid motor if taken care of. There are many of them that make it well past 300,000 miles (482,000 km).
I thought that might be the case. In my 'Bird, unless I'm late for work or something, the engine hardly ever goes over 2500rpm so its not exactly worked hard.
Can't tell if it is an HPP car or not (it has the wheels, and rear air suspension, but there are two different rear air suspension setups), but 235 hp is the rating for dual exhaust.
If it is an HPP car than it has the better torque converter and 3.27 rear gears instead of 2.73, it is an 01 so it is a PI engine car, only thing to watch is the plastic intake, just like the 96/97 mn12s.
I have a 2000 Grand Marquis, I have 135,000 miles on mine, and other than a leaking intake and the COP/sparkplug boots are cracks and I have a misfire, it has been a great family vacation and daily driver.
I've heard a bit about these plastic intakes causing problems. Is it only if they're disturbed or if the engine overheats, or are they a potential problem that could happen at any time?
They weaken over time because of heat. At least that was the case for mine to break. I ran it a lot in the summer and then the following spring it blew up. Other than that the car is one tough sonofabich. They are meant to be work horses. Great cars I owned a slow 97 but I still loved it, a comfy pimp ride.
So after it breaks is there an aluminium version you can change it to, or do you have to fit replacement plastic ones?
I notice that you're in Arizona, are they more prone to breaking in the hot states or doesn't that make any difference?
I actually blew this intake up in IL weather, something not unlike the UK. And yes I can see these intake not lasting long at all in hotter states but then its all in the way you drive. And yes there is a replacement with an aluminum crossover this will solve your problem. There 2 kinds of intakes PI and Non-PI. Not sure which one you want.
Ok, well at least there's a fix. I may have a look at the car next weekend so I'll have to see if I can tell what its got.
One other thing, I just got sent some pictures of the Mercury I'm interested in, and the plug wires look like thin grade wire. Would I be correct in thinking that this would be because its coil-on-plug, and the only wires running to the plugs are Low Tension, so thinner that normal plug wires??
Just curious ... are these (Bird & Marquis) right-hand drive cars for the UK? If they are standard left-hand drive US cars, what if any restrictions do you face in driving them there? I seem to remember a Car & Driver magazine article about a 'Vette trip across Australia, where the standard left-hand drive car was required to display a "Lefthand Driver" bumper sticker whilst being operated Down Under.
If you have right-hand drive Fords there, I for one would be interested in seeing some photos of them.
Regards,
Larry W7LES in Cheyenne Wyoming
Just to let you know, I had a 94 crown vic that no matter how hard I tried, I simply could not kill this car. The odometer stopped working at 285K miles, and the car is still going strong. When I bough my MarkVIII, I didn't have any room to keep it, so I gave the car to my cousin, and it is still going strong. So don't worry about the miles; for that car, 160K is nothing, and there is no reason you shouldn't be able to get another 160K out of it.
Regards,
Sorry to disappoint you Larry, but the T-Birds, Mercurys and 99% of all American cars in the UK are left hand drive.
I actually own an 87 Firebird as well as the T-Bird, and both of my cars came over with American servicemen (who can apparently bring their own cars over to the UK if they're stationed here). You ocasionaly come accross a RH drive American car, but they've normally originated from South Africa, or been specially converted. The only exception to this are some Cadillac STS's and Fourth Gen Camaros/Firebirds, as I think I'm correct in saying that they were sold as RH drive over here for a while in the 90's by GM. The majority of American cars in the UK have been brought across as personal imports, or shipped in from Japan. In fact I found out the other day that the Mercury I'm interested in originated from Dubai
I saw a magazine article a few years ago promoting a UK firm that bought US trucks (Rams and F150's) and did their own specialised conversions to convert them to RH drive. I'm not sure if they're still in business.
There are a few people over here who have a desire to own a real car, rather than the ridiculous number of Asian/European "cars" that are forced down our necks (2 litre engines are considered prety big!). Most UK people that own American cars tend to keep them mainly for weekend use due to the cost of fuel (currently the equivalent of approx $5.75/ UK gallon). I think I'm in the minority as I use my T-Bird as a daily driver. The dealer I bought my two from won't buy RH drive versions of American cars in the UK, as most people who look for American cars in the UK want "real" American cars, not American cars that someone has tried to make British.
Once an American car has been imported, we have to modify the lights to make them dip to the left, fit amber turn signals, rear fog lights, and fit UK style reflective numberplates. Once that's been done we can get an MoT test, (not sure what the equivalent is in the US - its a roadworthyness test thats done anually like other UK cars) and we're good to go. No LH drive bumper stickers etc. Just the ocassional weird look from pedestrians wondering why you're sat on the wrong side of the car.
98+ Crown Vics/Grand Marquis got COP, Coil On Plug, so yes, each cylinder has a coil, and it is only 12 volts and ground trigger to each one.
Discussion Starter #16
OK, update on the Mercury - turns out that the 262000 on the listing IS miles not km. Had a pic of the speedo, and it clearly shows 421000km. Hmmmm
How much are they asking for it? What kind of shape is the rest of the car in?
Discussion Starter #18
It prob won't mean much to you as were talking UK £'s but £2500 was mentioned, although its on an auction so we'll see. Its up to about 1300 at the mo.
I bet you could get 2 of them in the US for the equivalent $'s, say $3500 (at $1.4 to the £)!
Yeah, you can usually pick up high mileage vic's over here for about $1000. How much does it cost to ship one over, and how much of a headache is it to get it registered if you do it that way?
Discussion Starter #20
I think it works out at about $1500 to ship across, its not too bad getting them registered, just takes a bit of time obviously for the shipping and then messing around sorting out the changes to the lights, turn signals etc.
1 - 20 of 34 Posts
