Cougar Pilot
The new Ford Windstar and Mercury Monterey will get the 4.2L V-6 (201 hp/265 lb-ft). Hopefully this engine would be able to be swapped into the MN12 like the F-150 4.2L. And there should be plenty of junk 4.2L minivans in the junk yards in the future.
NRL said:
Why wouldn't it work. You can take a 32v lincoln continental FWD engine and swap it into an mn12.
As long as they are using the same engine, you would just have to swap motor mounts. Mabye a couple of other things too.
danman
CatBird Creator
since when was a lincoln continental fwd??
No it won't work, the Current 3.8L splitport in the van has a different bellhousing pattern, the same pattern used in the 3.0 OHV and 3.0 DOHC FWD engines. I willing to be they still use the same bellhousing for the 4.2L FWD engine. Also the crankshaft is about 1" shorter in the FWD engines.
Actually, watch for an AWD model of the Monteray.
Thomas
