1 - 20 of 29 Posts
i haven't done it, when i do mine or if i do i'm just going to weld it shut on my headers,u could do the same on ur manifolds
cut a peice of steel out the size of a penny put it on the hole and weld it
MaleWhore
You can also just buy a bolt and cut it to a decent length. Make sure to add some locktite.
+1...
did that on my kooks when i threw them on before i put the engine back in the car...works great!!!!!!
what does deleting the egr do
I did it because my car will, hopefully, never see the road again and my valve was broke. So its either buy a new valve ($$$) or weld everything up (Free).
I just stopped being a puss, took button head bolts, dropped them in the holes and welded them up.
How much does it affect the gas millage??
I would think 'millage' would go up? How bad is it on emissions though? I assume it won't pass in most states?
Refrigerator Raider Hater
It won't pass in ANY state. Some people get by with turning it off in computer, but it's pretty obvious when you open the hood.
Won't it also reduce IAT's significantly on an M90 application? Should be good on power. My EGR blows right into the plenum cover.
1 - 20 of 29 Posts
