Question...
This was supposed to be....Is there a difference between the throttle bodies found on the 94-95 Birds with the intake elbow versus the throttle bodies found on the 96-97 birds with the plenum upper intakes. I will be purchasing an accufab upper but I don't want to get another TB if I don't have to. Get at me.
House
From what I have been told is there is no difference. Like I think that you could buy a TB for a 96+ mustang and it will fit on 94+ MN12s. (from what I was told) I actually took mine off and held it to a 70mm TB for a 97 mustang and it looked identical accent 5mm dif. and the other was BBK and shiney.
Clay
Cougar Pilot
No they aren't the same. You can use an F-150 aftermarket TB though. Otherwise the intake and plenum changed on '96+ car engines.
yes they are not the same the linkage is reversed.
