If I were to purchase the BBK throttle body... than I need the same size mass air flow sensor as the throtle body right? Would these mods effect the performance of the Dennis chip?
I believe for some air flow reason the TB should be smaller then the MAF. Get a 70mm TB and a 80mm MAF and you should be fine. You will need a chip to get a new MAF
If your engine is basically stock.....
95zr7 said:
Where do I get the MAF from??
go with the MAF if you want, but don't waste your
money on a larger TB - your stock stock heads, cams,
and exhaust don't flow well enough to need a larger
one....
Hope this helps,
