On the kickdown cable that runs alongside the throttle cable, there is a little tab that is supposed to be bolted to something. I'm not sure where it is supposed to hook to. Does that go on one of the exhuast manifold studs or on the back of the head? Thanks.
Thomas
*EDIT* 1993 Thunderbird LX 3.8L NA
not exactly sure what part you're explaining, but I know that all three cables on the throttle body snap into a clip on the front of the upper manifold. If it's a different part could you describe it better? Or pictures would be nice too. I can take a look at my car tomorrow and try and figure it out.
-Thomas
If I'm envisioning the clip you're referring to, it snaps into an unused bolt hole in the back of the driverside head.
-Rod
yes, mine was on an unused bolt hole on the back of the drivers side head. The clip was a real pain to remove and I broke it. Its not going back on there thats for sure...
