Having some sort of problem with my gas pedal feeling strange, its not sticking but it has wierd sensation that its grabbing or there's an obtruction of some sort. The spring looks good although rusted and the cable seems ok. moves freely. My son thinks it could be the butterfly in the throttle body sticking or bonding. Any ideas?
yea check ur butterfly in tbody there not hard to take of on the 94's. clean the tbody brake clean the red can. and see if that helps. other than that u might have a broken cable might be kinked inside.
heard that chemicals for throtle body is not good, throttle body has some sort of coating in it that can be damaged. Is this true? if so I,ve seen throttle body cleaner in thr auto stores, I guess I could use that.
