1 - 20 of 21 Posts
I wouldn't use it. TB/Carb cleaner is corrosive.. you don't want to corode or mess up those MAF wires. I used Windex to keep em clean.. no problems.
so windex works fine huh? .....i'll have to try that.....in my quest to solve my low gas mileage problem.....
Discussion Starter · #9 ·
Spray windex on already *clean* glass and let it almost dry out, then wipe. It should smear.
Then try that with vinegar and water.
You don't need much vinegar. 50/50 would be too much. All you need is 1/10 vinegar/water. Your wife/Ma/Girl friend should be able to advise you on that.
You guys also know to us newspapers to clean your glass, right?
Discussion Starter · #12 ·
Aahhhh... but I didn't say not to. I just haven't done it. I was hoping someone who's cleaned their MAF might offer something. I checked mine today and it looked clean, so...if it ain't broke don't go fixin' it.
Personally tho, I would do the Q-tip thing. Just have to be careful. Now don't go suing me if you do that and break your wire.
Using the q-tip works good, but you do have to be careful, and you might have to readjust the wires afterwards, also make sure you don't leave no q-tip on it
Sheepish
What about using Electronic Tuner Cleaner? Think that would screw with it?
LOL.. you guys ask alot of questions.
Windex and a Q-tip... make sure it dries before reinserting it back into the MAF unit. Be careful not to bend any of the wires... or thats $230 down the drain.
First time I did it, I felt a noticeable difference in throttle response.
I'm sure it would work fine, since it's probably like an electrical contact cleaner. Instead of using a Q-Tip, one could also probably use a can of compressed air (find it anywhere they sell computer stuff) to blow off any particles.
any other way to clean it with out having the tamper proof bits?
1 - 20 of 21 Posts
