What would be the best setup with the Thrush Turbo muffler. Mid-mount, or stock location? Single or dual out? If dual, should I y-pipe and then run 2 mufflers, or run a single into the muffler then have a dual out muffler and run it back? If I mid-mount it should I run a pipe to the back, or just mid-dump it? If I run a pipe, should I go to the back or out the sides (if dualed)? Should I keep the resonator or ditch it?
