It is nice
Ok I just replaced my LCA's im still not sure how to tighten the strut rod @arm down since it just keeps spinning its set at 8 threads from the tip where it was before. It's on tight but I'm not sure on how to torque it correctly. I'm also replacing the tie rod ends I have the adjustment nut loose and the cotter pin and nut off on top. Now how do I get the end popped out both my tie rod end pullers don't fit as the brake shield is there. How do I remove it? Thanks.
use a pickle fork and beat the living shiznit out of it to get the tie rod off.
im not really sure what your asking in your other question.
It is nice
nevermind the first question I figured that out just needed it tighter. One thing though; on my drivers side i tightened the lower ball joint nut and as it came down I could feel the whole joint spinned a bit. Then I realized I forgot to use a jack and lift under the lbj and finished tightening it. Do you think it got damaged like that? O well on to the tie rod ends any easier way of getting them off?
It is nice
ok i did it!!!! lol took off caliper and rotor had enough room to put the puller in kinda slanted but worked. I went flying back like 2 feet when it popped surprised me lol. one more side and im done.
