So turns out my valve seals are shot on my svo bird.. so I was looking into the trickflow 44cc heads and a set of comp XE268H cams. Would this be a good combo? My full build specs are in my signature. Thanks!
Oh hell yea! That's the same setup that I ran 11.5 at ~117 mph with on E85.
You'll want to switch to the 42 lb injectors and have the car tuned. Also to go E85 you'll need a higher capacity fuel pressure regulator.
RobertP can talk you through it.
Didn't you have to go to E85 due to pump gas not cutting it?
This would be a nice compression bump, and those cams would rock. :)
The book I have of various builds mentions wishing TF made a 4.6l head; it was from 2006. :)
93 pump gas will work fine with a stock bottom end and 44cc TF heads. The compression ratio is around 9.5:1
My problem was with my new engine having a 11.5:1 CR.
It doesn't like 93 Pump gas.
Awesome! I was hoping I’d be able to stick with the 93 octane, I don’t mind stepping up injectors, but I just replace all fuel system components and didn’t want to do it again. Also trunk monkey do you remember the hp & tq your car made on the old set up?
1st Pull: 382.92 rwhp / 388.71 rwtq
2nd Pull: 375.94 rwhp / 392.02 rwtq
Run Conditions: Temp. 74.77° F, 29.73 in-Hg, Humidity 10%, SAE 1.01
All the details are in my garage. I sent you a link in the PM that I replied to.
Nice! Thanks for the info! I’ll check out the link
