Hi Guys,
I am in the middle of doing a head swap on my 95 T-Bird LX 4.6 2V with rebuilt PI heads that I pulled from a Grand Marquis. I realized that I could bend valves..
Here is more information:
1) The heads are torqued down.
2) I tried to make sure the pistons were down in the bore before I placed the heads on, but the crank key way is around 6:00.
3) There are no chains or other timing components installed yet.
4) The Right Cam sprocket looks like its near the correct location around 11:00. However, the Left Cam sprocket is off and looks like it needs to be rotated back a turn.
5) I have not rotated the crank or the cams any since the heads were installed.
Here are my Questions:
1) Do you think I have already bent any valves based on the positions of the cams and crank?
2) What's the best way to rotate the Cams to the correct timing position without bending any valves?
3) Should I remove the cams and followers on both sides in order to time the engine at this point?
4) How do I get the crank back up to TDC once the cams are in the correct position ?
Thanks - I am a little green but any help will be greatly appreciated.
