1 - 15 of 15 Posts
Does anyone else on here have noticeable timing chain noise, or is it normal. As long as I have owned my car you could always hear the chains rolling around in there, its not loud or anything, just noticeable.
i can hear mine with the mechanic stethoscope (ie screwdriver up to ear) i have never noticed it without doing that, maybe im deaf tho i dunno. i would consider replaceing the timing parts when you install your "2004/2005 ALL Aluminum 4.6L"
I wont have to because it will be with the new engine;)
with 230K mileage is a little noise to be expected? I guess this should be directed towards the high mileage people.
mine doesnt....although im curious now if anyone makes timing gears for the 4.6L...i like the way they sound, kinda like a supercharger.
no i doubt they make timing gears. there would have to be about 10 gears just to do it. haha to many mechanical parts for me.
Timing gears, yes. Gear drives (which is what you're talking about), no.
-Rod
If the plastic peices on my tensioners are worn, could this be a problem?
Its not a really loud annoying noise, you can just tell their doing their thing, the chain isnt slapping the timing cover or anything, lol
I would think your oil feed tensioners might be sticky or have a bad internal spring. Only 4.6 I know of with timing chain noise had the oil tensioner with a broken internal spring.
Yeah Nick and that was my car. After tearing the front of the motor down 3 times in a 2 week period I am a pro now on it.
I had no noise at all until I took it apart for the first time and squeezed them together cleaned the tensioners and put them back on and the passenger one did not pump back up.
Thanks for the save on the tensioner Nick.
So is this something that is really serious because its been doing it for a year without any issues, I dont really drive it anymore cause its winter and stuff.
pull the valve covers and have a look. Dosent cost that much to take a peek inside
You will not be able to see much unless you remove the timing chain cover and if you do that you might as well be ready with parts to replace the tensioners and chain guides or even the chain itself. I only took mine apart to install PI cams, that was a nice seat in pants increase.
1 - 15 of 15 Posts
