metal grinding, when pressure is up, odd tapping/slapping from the front of the timing case
so i just got the cover off and i have no idea what im looking for as far as bad parts, can anyone point me in the right direction
Check to be sure your tensioners are tight, that your cam sprockets are tight and the bolts holding the cam sprockets on are tight (they should be 90 lbs-ft). Check for excess slack in the chain itself.
your looking for excess wear on the guides, or if the can be pushed down by hand, if theres any slack, etc...
