I searched, but nobody seems to be having the same difficulty as me. What is the easiest way to get to the compressor bolts? I can't seem to fit a socket in there cause the pulley is in the way. Tried to remove the pulley but only the front came off. Any help is appreciated.
3rd Gear Chirper
try a box wrench, or even an open end. the open end may round off the corners if the bolts are tight so try the box wrench first.
Try two swivels, an extension, and definately some gloves to protect yer knuckles. Good luck.
