1 - 20 of 23 Posts
what are the best tires for my stock non sport tbird ??
mustangs n tbirds have the same lug pattern???
whats yalls opinion on the cobra wheels on a tbird?
For best tires, do you mean stock replacements or aftermarket? And what respects are you looking for; traction, looks, price, handling...?
Non sport stock wheels would be 205 or 215 15s, unless he's already gone aftermarket.
I went with Firestone Firehawk Indy 500s 215/70/15 because IMO they're the best bang for the buck. If you look them up on tirerack they get the best ratings out of all similar tires, not to mention all rated categories are either "excellent" or "very good." A set of four tires for under $400 with excellent all around all season traction. Not a lot of road noise either. Not to mention they look cool. A lot of people on here seem to like Cooper Cobras and BFGoodrich Radial T/As as well.
I can give you a more detailed opinion of how I've noticed how they perform, as well as some pics if you're interested.
Firehawks are good, my personal favorites are a subbrand of Goodyear called FIERCE. Buy FIERCE UHP tires, they're Z-rated and even though they say "245" they have a LOT of footprint to them. They look more like 275s than 245s.
They are definitely EXTREMELY grip happy, too. I have a set of 245/50ZR16 Fierce UHPs on the GF's mustang.
QUANTUM improvement over the Bridgestone FUZION HRi's that were on it.
I'm running 245/60/R15 on mine; looks good and has some grip. I used Dunlop GT Qualifiers and love them. I will probably stay with Dunlops (used to run BFG and Firestone). None are bad tires!
I ran that size on all four corners... looked good and drove nice.
hey traveler, by chance your related too larry allen. used to work form him back in the 80's. now live near mokan should try to hook up. sorry for breakin post
LOL Wow, funny you should ask. I'm not related to him, but he did buy the Ford dealership from my dad back in the 70's... So I do know him of course. I've been in and out of that dealership hundreds of times since I was a kid. He's got a GT-500 sitting in the showroom right now.
I do plan to get to MoKan as much as possible this summer... For the Fun drags. I'm anxious to find out just what I can run once I get the 3.73's in and the 255/50's put on. Love to see another T-bird there!
If you like white letters, hard to beat BFGoodrich Radial TAs or Firestone Firehawks for looks. I also have some Lemans SR tires (same as Dayton / Bridgestone / Firestone Firehawk Indy 500, same tread, different letters) in 215/70-15 on the rear of a GoldWing Trike that look good, and the lettering is balanced .... they are good looking tires.
A 245/60-15 is just a itsy bitsy hair shorter than a 215/70-15, but are much wider. The charts reccomend a 7-9 inch wheel for them, you have 6.5 inch wheels. They'ld work, others have done it, but they will really bulge from the rim and probably squirm around some. They'ld be about the widest you could run.
Personally, on a 15x6.5 inch wheel, I'ld either go with the 215/70-15 at all 4 corners or 235/60-15 at all 4 corners (I've seen 245/60-15s on a 7 inch wheel, lots of bulge even then.). 235/60-15s are reccomended on a 6.5-8.5 inch wheel.
The figures below are from a chart where you can enter info and compare. Because both the 235/60 and 245/60-15 tires are shorter than 215/70-15 tires, to run the same actual ground speed, your speedo will read slightly higher. Or, in another sense, you get a cushion added that maybe prevents a ticket someday .... as every officer has that "certain magic number" in mind when working some radar, a number over which he considers you fair game.
Stock Tire - 215/70R15
Section Width: 8.46 in 215 mm
Rim Width Range: 5.5 - 7.5 in
Overall Diameter: 26.85 in 681.99 mm
Radius: 13.42 in 340.86 mm
Revs per Mile: 774.6
Actual Speed: 60 mph 100 km/h
Tire 1 - 235/60R15 (be my choice)
Section Width: 9.25 in 235 mm
Rim Width Range: 6.5 - 8.5 in
Overall Diameter: 26.10 in 662.94 mm
Radius: 13.05 in 331.47 mm
Revs per Mile: 796.9
Speedometer: 61.7 mph 102. km/h
Tire 2 - 245/60R15
Section Width: 9.64 in 245 mm
Rim Width Range: 7 - 8.5 in
Overall Diameter: 26.57 in 674.87 mm
Radius: 13.28 in 337.31 mm
Revs per Mile: 782.8
Speedometer: 60.6 mph 101. km/h
A new tire comes with about 10 or 11 / 32s rubber. A well worn 215/70-15 is 26.85 inches diameter minus the 16/32 you wore off, or about 26.35 inches diameter. A new 235/60-15 is 26.10, or exactly about 1/4 inch shorter, that's 1/8" less tread rubber. The height is that close, you'ld not notice it.
Also, these birds once used a bastard size tire that first appeared in the early '80s on the Monte Calo SS, Buick GN, Cutlass 442, Pontiac AeroCoupe, and etc, a 215/65-15 that was shorter itself. My '92 Sport came with this size tire and is so marked on the door sticker.
It's short looking, :eek: but there was room for tire chains. :tongue:
Tire 3 - 215/65R15
Rim Width Range: 6 - 7.5 in
Overall Diameter: 26.00 in 660.4 mm
Radius: 13.00 in 330.2 mm
Revs per Mile: 800
Speedometer: 61.9 mph 103. km/h
For a really long legged Bird on straight west Texas roads like ...
... you could use somethinkg like those below on back, but ..... note that since they are TALLER, your speedometer would read lower and you'ld be going the same speed, like 57 mph on the speedo would see you actually going 60 mph .... which works against you when you fly through radar maybe.... but if one is so inclined to run 85 or 90 in a 70 zone, whats a few more to them right? :)
Tire 4 - 225/70R15
Section Width: 8.85 in 225 mm
Rim Width Range: 6 - 8 in
Overall Diameter: 27.40 in 695.96 mm
Radius: 13.70 in 347.98 mm
Revs per Mile: 759.1
Speedometer: 58.7 mph 97.9 km/h
Tire 5 - 235/70R15
Overall Diameter: 27.95 in 709.93 mm
Radius: 13.97 in 354.83 mm
Revs per Mile: 744.1
Speedometer: 57.6 mph 96.0 km/h
Your choice depends on your driving and budget.
Curvy:
Straight:
Trust it was helpful ...... :rolleyes: :confused: :( :D
I've got the Firehawk Indy 500's in 225/70/15 on my '95 T-bird and I'm very pleased. Good bang for the buck for sure.
1 - 20 of 23 Posts
