1 - 12 of 12 Posts
What I’m looking to run is a 15X7 rim with 4.125 backspacing and 215/70/15 tire in the front.
In the back will be 15X10 rim with 4.25 backspacing and 295/50/15 tire.
Anybody ever run this setup?
Discussion Starter #2
Dose anybody know about this?
Isn't the stock offset 4 inch?
Doh! I thought I read 15x8 on the front. The 15x7 should be fine. Have you done or doing a hub swap?
No, Still the pathetic 4.25.
Even with a hub swap those are going to stick out. Those are negative offset wheels . Our cars need positive offset wheels.
Don't think for a minute that you can use adapters to use those wheels.
I'm really starting to hate my wheel choices. I just noticed that none of the SS Cragar's have a 4.25 lug pattern
1 - 12 of 12 Posts
