1 - 13 of 13 Posts
Would this tire fit on my 97 bird?
245\45\16
Do you mean it would look too small?
They would also make your speedo about 5 MPH off (too slow) Try a 245/55/16
go with the norm 245/50/16, there's a bunch of tire choises and they are only about an inch shorter then the stock mark viii height. (is the t-bird the same??)
What is the factory size 16" tire?
the 245/50's are slightly shorter and wider, look a hell of a lot meaner then the stock size too. Throws off the speedo a couple % but nothing major
The 245/55's are the same diameter as the stock tires. According to the website mentioned earlier.
yea they probably are, just go and see how many tires are aviliable in that size. Then see how many are aviliable in 245/50 =) you will see my point
Ahhhhh I understand that real well. Try finding a 245/60/15 !!!
1 - 13 of 13 Posts
