Car still needs quite a bit of work. My best run was
60ft..........1.8635
330ft.........5.6631
1/8et.........8.84.02
1/8mph.......76.56
1/4et.........14.06
1/4mph......89.03
combination is stock markVIII short block, stage 2 heads from MHS, custom ground cams, trick flow intake, 3.73 gears, 5000+ stall singleplate converter (Rob said it didn't work :0 ) 24lb injectors, 02 gt maf, needs tuned badly,70mm throttle body and no bracing yet. it is laying over just before the 1/8th if the mph doesn't show it. I am sure I can get the 60's down in the 1.7 range and think I can get it into 12's with some practice and minor changes.
Alan
Alan, sorry I didn't get a video of your bird, I left before eliminations. I love the set up though, tons of potential for a fast 1/4! :)
I have high hopes for the setup if I can just get the tune dialed in right. Serious potential for the fact I have less than $2400 invested in the entire car. We started a local race team based on budget built birds and cougars. Recession Racing!
The car made 2 passes real well and then I think the plugs started fouling out because it slowed way down. I really need to talk Dalke and or Fraser into doing another tuning class for the tuning illiterate such as myself.
Alan
