1 - 2 of 2 Posts
Did you have to drill holes in the front fender to mount them up? I bought a set today and the rear ones bolted up fine with 3 screws, but im noticing that theres only one screw on the front fenders.
Yes, you'll need to drill the front. If I recall, you should be able to drill the plastic splash guard and not the sheet metal of the front quarter panel. Also, if you have OEM front mudflaps be sure to line the dimple in the mudflap up with the dimple in the rocker panel at the bottom for a perfect fit.
  • Like
Reactions: KULLER94
1 - 2 of 2 Posts
