1 - 2 of 2 Posts
im going to put toggle switch to replace the headlamp switch. i have a 97 switch in my 91. but i want to put a toggle switchs to give it a racing look.
first one is park-amber(brown wire and ground)
second one is head lamps(red/yellow thick wire and ground)
third for the inside light
i'll ditch the dimmer thing.
all will be on a triple switch kit and will light up when the headlamps come on.
plus i can just put the headlamps on without parks the taillamps comeon with the igintion(led blubs do that only a bit dimmer then the parklamps)
so good idea or not.(plus i dont have to worry about the blinking headlamp problems the m12s have.)
3rd Gear Chirper
Uhh, I guess that will work but you'll need to make a custom switch panel of course. Make sure that if the old headlight switch has circuit breakers built in that you use new ones with your setup or at least use fuses.
1 - 2 of 2 Posts
