Thanks. I'll order a TYC for now. It looks to be closest to OEM.I’ve had good luck with TYC stuff. Spectra used to be pretty good, but has really gone downhill in the last few years, so I would avoid that one.
Which SPAL do you use? Can you provide a size and model number? Thanks.I read up a LOT on aftermarket low profile high flow fans and I ended up investing in SPAL fans.
There are some other fans which quote higher CFMs but in several comparison videos on youtube, it was obvious which fan blew harder for the same amp draw.
I went a little nuts on cooling because we went to 2 or 3 races in a row and didn't get to race flag-to-flag. This is what got me to overbuild the cooling and oil system.Thanks. I'll order a TYC for now. It looks to be closest to OEM.
Griffin Radiator (GRI-1-26242-X) w/ 1/8" bung welded in for temp sensor |
- Griffin Radiator requires different radiator hoses: Upper Radiator Hose = DAYCO #72077 (slightly trimmed at radiator end) Lower Radiator Hose = DAYCO #71901 (slightly trimmed at WP end) |
- Griffin Radiator requires radiator cap from 2000 Chevy CK2500 (Stant 10331 or CST 7816) |
- Griffin Radiator requires custom brackets |
- 16" SPAL pusher fan (#SPU-IX-30102048) installed on Race Radiator - 19amps (SPAL reccommends 40A fuse) - 12" SPAL puller fan: (#SPU-IX-30101504) installed on Race radiator - 13 amps (SPAL recommends 25A fuse) |
Thanks so much Gunn! As you may know, I've got a custom build Fluidyne. I'll add that SPAL pusher to the front in addition to the TYC puller that I ordered. Should help tremendously! I"m going to get a little crazy with my cooling too, I'm tired of sitting in traffic an watching the engine cook. I ordered the Fluidyne radiator but just discovered that my fan really wasn't working. This high compression stroker makes a LOT of heat!I went a little nuts on cooling because we went to 2 or 3 races in a row and didn't get to race flag-to-flag. This is what got me to overbuild the cooling and oil system.
From my notes:
Cooling
Griffin Radiator (GRI-1-26242-X) w/ 1/8" bung welded in for temp sensor - Griffin Radiator requires different radiator hoses:
Lower Radiator Hose = DAYCO #71901 (slightly trimmed at WP end)- Griffin Radiator requires radiator cap from 2000 Chevy CK2500 (Stant 10331 or CST 7816) - Griffin Radiator requires custom brackets - 16" SPAL pusher fan (#SPU-IX-30102048) installed on Race Radiator - 19amps (SPAL recommends 40A fuse)
Only thing I noticed was that I had to make sure my wiring was beefy enough to handle the current. I noticed some 14ga wire was getting a little melty so I had to beef up the wiring to 12 or 10ga from the relay and to the fan itself.
IIRC, these were the largest fans from SPAL with the highest CFMs that would fit my radiatorI was under the impression that a pusher fan and puller fan working in tandem could product varying results. I was looking into this not too long ago on another topic on this forum - the one about the PCM fan speed / temperature settings and fan speed operation at vehicle speed where the airflow coming into the front of the vehicle may overcome the fans ability to operate efficiently. I ended up reading a bunch of posts from engineers on technical forums about fluid density flow properties.
I dropped the research since the debate was pointless but this still is a topic of interest that may relate to what you are doing. You need fan operation at idle while the vehicle is not moving obviously.
I guess the only thing i am trying to bring up is that one fan may reduce the efficiency of the other if you have a more powerful pusher fan working against a puller fan. Does this make sense ??
RADIATOR COVERAGE CALCULATIONS | ||||
Single Fan | 16" Pusher | 30102047 | ||
11" Puller | 30101500 | |||
Dual Fan: Black Pusher & Red Puller | ||||
Desc | Width | Height | Total Area | |
Radiator | 22.5 | 18.91 | 425.475 | |
COVERED | 16" pusher Fan | 16 | 16 | 200.96 |
16" Square | 16 | 16 | 256 | |
COVERED | 11" puller fan | 11 | 11 | 94.985 |
11" square | 11 | 11 | 121 | |
OPEN | Area NOT covered above 16" Fan | 2.91 | 11.5 | 33.465 |
OPEN | Area Not covered below 11" Fan | 6 | 7.91 | 47.46 |
OPEN | 3 quadrants NOT covered by 16" out of square | 41.28 | ||
OPEN | 3 quadrants NOT covered by 11" out of square | 19.51125 | ||
Approx | AREA NOT covered by Fans (actually a hair less) | 141.71625 | ||
Percent Coverage | ||||
Single 16" Fan | 47% | |||
16" and 11" fans overlapping | 67% |
