1 - 20 of 33 Posts
Overkill Fetish Freak
Yes, you can install a Roots blower on a 4.6L. Installing one from a 3.8 SC would not be easy and expensive. If you want a Roots kit then look at the AED, Sally-een (saleen), Kenne Bell (soon) and SVO kits for the 4.6.
-Scott
dam dude is that ur car??? where can i find links to these root blowers for 4.6l, is it easy to put them on? 50state legal?
AED looks "interesting", how long do those things last, and what kinda belt would i need to make that fit
to do this AED SC, do i need to have forged internals? or any hi po parts? 6 and 9 psi which would i want
You don't need forged internals with the AED kit but it would be a good thing to do when adding any type of forced induction to a stock motor. Read the articles in the tech section regarding the AED kit install for more info. A bunch of guy's run them here without any issues other then the fact that the Alt is backwards. I would start with the 6 PSI pulley.
-Scott
When I ordered the 9psi kit from allen they said that I may blow my motor. Running 6psi on a stock motor is fine, 9 is really pushing it. My motor is still stock no PI heads nothing. When I blow it I'll have it rebuilt from the ground up, stronger then ever.:D But until then I'll press my luck!
ya allen blowers are mucho $$$$$$, say on a lightly mod-med modded 4.6 what hp increase and torque would i be lookin at?
Only you can prevent modular fires
Just do like i did find a guy with a mustang thats upgrading and get his old 4.6
You "can" use a Vortec or a paxton blower but I would say the vortec is the better bet after doing mine.
with the Allen root blower how much MPG would i look into loosing, ppl are telling me i could loose 10mph etc.
Discussion Starter #15
well then what would be good for me!! i want to walk a z28 thats my goal at this point. and still get a good, ya GOOD MPG i want over 20 on the highway fo sure
In this case you will not be able to walk a z28 and get good mpg. Just aint gonna happen (Or at least I don't think so). Sorry
Discussion Starter #18
jurgan im selling the 5.0 and hope to find me a decent 96 4.6l so ill pimp with the 96 unless i can find a really good 5.0
Try a Turbo? The power comes off of the exhaust gases, which are basically doing nothing anyway! A supercharger uses a belt driven off of the engine. Of course, anytime you put your foot into it to beat a Z28, you're going to use lots of GAS!!!:D
By the way, good luck in your quest and let us know when you kick Z28 A**!
1 - 20 of 33 Posts
