1 - 20 of 29 Posts
My TCC on Lazarus, the black Cougar, is stuck on, in every gear except 1st. :)
I've checked the solenoid, Valve body, check balls; pretty much everything you can look at with the tranny in the car.
It actually drives ok, if rough, lol.
Are there any shaft seals that can cause this, or a particular valve in the VB?
I'm building one to replace it, but it would be nice to know what to look for. :)
Discussion Starter #2
I actually love the way this drives on the highway. :)
The Poly/sport/koni suspension is settling in; I May not need a back brace after all...
It always disengages at a stop, or a manual 1 shift. :confused:
In my experiance it sounds like a bad solenoiod. I've had them ohm out just fine n still be stuck on cuz it kind of welds itself together after the first application
I've already replaced it with a new one; the old one wasn't bad, either.
This almost has to be a seal on a shaft, or a wormtrack cross-leak in the VB.
I ain't found it yet, tho. :D
I'll throw out an off-the-wall question and ask if you've checked the voltage on the wires to the solenoid... Just in case the PCM is fried or the wiring is fubar'd.
Yeah, once I saw how easy it was to access from the inside, I ohmed it out.
I checked the circuit while I had the solenoid out when I changed it, as well.
There's a valve in the valvebody that can cause it, so I swapped the VB with another one, and it still has the same problem.
I've been driving it for a year, every few days.
I will probably do a 4-2 or WOT 2-3 one of these days, and it will take a large sh*t on me, most likely; it needs some play there. :D
Something is leaking somewhere... (internally, not externally)
I don't have the VB wormtrack data or the tranny housing fluid flow circuits to look at; if anyone has the resources, point me that way.
Those are awesome, Chris; I downloaded them a while back.
That's how I'm thinking a checkball, maybe.
Is there a diagram that any of y'all have seen that has the description of the wormtracks in the VB?
Or what flows thru what holes in the shafts?
I know the official FLM 4R70W manuals have the complete hydraulic path for each function. It is quite elaborate and way too much to post! :eek:
I'm not sure where my manuals are, but I'll look around tomorrow. If I find them, I'll snap some pics of the lockup circuit and post them. I'm afraid they may be in one of the 50+ storage totes still at the storage shed from remodeling the house over the past year. :rolleyes:
Driller, if you can tell me what book to buy, I'll do it!
Posting pix is nice too, tho. :)
I'm in for the long haul; when I figure this out, I'll post it up.
I'm resizing teflon seals today, lol.
Discussion Starter #12 (Edited)
Cool beans!!
Thanks for the link; there was apparently a "powertrain..." book, and I've searched for one, but never found it. I think it was a "helm" manual.
Do you think the ATSG manuals that cover the updates, in addition to the linked manuals, will cover everything?
I already have those; the TCC circuits are not mentioned in those at all. :)
I'm interested in what you find. Mine does this also in my drag car. It even locks at the top of first gear. Its only real annoying when its cold and I drive the 100 yards to the first stop sign, it drags the motor down then finally releases. Other than that I think its great for ET's.
I believe Jason Millers also does this.
Mine has been rebuilt a few times. I think with a different VB once. I have a VB from a Marauder I am going to try when I get around to getting the car back together. Its a 95 trans with the extra direct clutches and the mech diode one way.
I used to have one of the B&M shift improver things on it. The electric module that goes inline on the computer wiring. So maybe that fouled the computer that was previously mentioned.
Here is a log of it locking in 1st. This is with a triple plate CC. I have a log somewhere with a single plate CC its not as noticeable on the graph.
Discussion Starter #16
Is it possible to add a value file that writes something I don't have the ability to change, and then later when I remove that function, the parts I can't write are still there?
Like, can I make changes with PRP and value files that writing my base file back in won't change back?
Absolutely. This is actually a periodic discussion point on the PRP forum... the only solution is to re-build the tune from scratch referencing all the values you CAN control.
Or - do what I do - and save each tune revision as its own separate file. ;)
Discussion Starter #18
I'm wondering if I used the "Lock TCC on dyno" option, and I can't overwrite it to put it back...
:confused:
:confused:
Thats an interesting thought. But would the OD light flash if that was still set? I remember while getting my car tuned after it came of the dyno the OD light was flashing and the tuner had to go back in to reset that, IIRC.
Sorry to semi-hijack this thread but I saw up above that Grog6 has changed out the TCC lockup solenoid. I've got what I assume is a bad TCC Solenoid which is causing code P0743 - Torque Converter Clutch (TCC) Solenoid Circuit Electrical. I have a 1995 Thunderbird with 4.6.
I've checked the external portion of the wiring harness coming into the transmission and everything appears fine. I've had problems for a long time with the TCC lockup on the car where it would lock hard and early in third and fourth gears. About a year ago it stopped locking altogether. I'm finally getting around to trying to fix the issue and having problems finding a new solenoid. Ford, Autozone, Advance Auto Parts, and Napa all say they cannot get this part and that none of their stores etc have the part to transfer. I assume my next step is to contact a transmission shop but wanted to ask here first. Can anyone point me to where I can purchase the solenoid if it comes to that? Is the part interchangeable with newer model vehicles with the 4R70W that I could buy the solenoid from?
Also, I gather that I can use a multimeter to test out the solenoid and that I should be able to determine if it is 'good' by the resistance reading. Can I also manually engage the solenoid by applying voltage to the connector with the pan off to check if it is engaging?
Thanks for any help you guys can give. I considered posting a new thread but this one was the closest I found to being applicable and I say Grog6 had bought a solenoid semi-recently.
Willum
1 - 20 of 29 Posts
