1 - 2 of 2 Posts
How would I determine if my TC is bad? Let me explain my symptoms. When I turn a sharp corner the tranny feels like it is slipping. Then when I am on a small incline my car rolls backwards. Also, when I am on flat level ground and I let off the break the car only starts to go when I press on the gas. All this just started over the last 6 months. Any thoughts?
1. How fresh is the fluid ?
2. Are you using Mercon V ?
3. Have you checked the fluid level properly ?
The 94-95's have a poorly design fluid pan, and you can get a slip in the tranny when making right turns, and when sitting on an incline.
The fix for that is a 96-97 pan with a deep sump, or a 98 pan with a deep sump and drain plug. You also have to use the same year filter for that year pan.
1 - 2 of 2 Posts
