I can tell you the transmission will hold 11 quarts with no cooler and an 11&1/4 converter. It will hold 12 with a 12 inch converter and generally the cooler will take about a quart.
Alan
Discussion Starter · #4 ·
I am replacing my current torque converter with a Marauder torque converter. I have fresh MerconV in my tranny. I was just was looking for the amout of fluid a 11.25" Marauder converter holds.
Faster than Porkchop
I'm about to swap in a MarkVIII convertor , are you removing the engine
or moving the tranny back .
I need some tips .
Thanks
Discussion Starter · #7 ·
I actually have the engine out ......................
I am about to install a new long block and while the engine was out for the rebuild I sold my stock 94 SC torque converter to someone that wanted a stock replacement. So I got a new flexplate and a Marauder/Mach1 torque converter.
