I have seen the gauge I am looking for in this site, but I have used the search and so far i have not found it. It is the gauge you use to torque degrees after you have done the four torque steps on the head bolts and then you back off and retorque so many degrees. Does anyone know what I am talking about and where I can get one. Thanks in advance for any help.
You don't need a gauge. Remember 360 degrees is a full turn of the wrench. Thats all it is.
If you need the tightning information here is what my manual says:
a. 50 n-m 37 lb-ft
b. 60 n-m 45 lb-ft
c. 70 n-m 52 lb-ft
d. 80 n-m 59 lb-ft
e. back off retaing bolts 2-3 turns
f. tighten to 15-25 n-m 11-18 lb-ft, then rotate additional 85-105 degrees
Resident *******
your probably going to want a torque wrench to do what speed demon said.
