I need to know if you can use a 96/97 tps and wiring on a 94/95 tb or even better yet if I can use a second gen mark tps on my first get mark throttle body. The reason I ask and need to know is I'm in the process of doing a motor swap in my 97, and the bird tps wiring would plug in perfect to a gen two mark viii tps sensor instead of having to splice in the old style of connector (93-95 mark/94-95 bird) into my 97 wiring harness. I've compared the two new sensors in person at pepboys and they look identical from what I can see other than the plugs.
Thanks for the help. I'm hoping this is one of those things that changed shape but retained function like iat, ect, iac, evr, etc....
Tps
I just went through all that, and 94-97 Thunderbirds / 96-98 Marks all use the exact same throttle position sensor. I don't know about the older Mark VIII's, but I would guess they are they same sensor, too.
(Also the same as 95-04 Crown Vics, 97-04 Trucks/Vans, 96-04 Mustangs, 96-99 Taurus, 95-02 Lincolns, etc, etc)
Unlike the IAC which Ford seems to have chosen a million different ones.....
EDIT: Here are some TPS part numbers my research has turned up:
Standard Motor Products TH157T, TH157
Original Engine Management 99035
Airtex / Wells 5S5115, ZZM318851, TPS245
Delphi SS10387, SS10386
Motorcraft DY967
BWD EC3025P
Master Pro Ignition 2-99035
BBK 1685
Echlin CRB 219094, CRB 219093, EC129
Ford F4SF-9B989-AA, F4SZ-9B989-A,
F4SZ-9B989-AA, F79Z-9B989-AA,
F80F-9B989-AA, F80Z-9B989-AA
Can anyone tell me if the pin out is the same between a gen 1 mark VIII tps and a gen 2 mark VIII or 96/97 tbird tps? Also if the operating voltage and voltage range are the same?
Chris_Murder
Chris_Murder
Alright, Chris. It looks like the plug is physically different, check this out:
Mark 8 Gen1 TPS:
Mark 8 Gen2 TPS:
As far as "pin outs", they are the same and as far as I know, ALL TPS's sweep from 0-5v so you can test them that way. You're welcome and good luck!
Thanks rick I think I'm going to try it. 96/97 tbird sensor on the gen 1 tb looks to me from a mechanical aspect that they are the same. The less amount of residing or splicing the better.
I'm going to revive this so i can ask a dumb question, but I'm not finding much info on it. so here it is...
my TPS seems to be at 18% when the throttles closed, is that normal? had a code for voltage out of range, and i had to change it the other day, and i noticed both the old one, and the new one sit at 18%. at least the code is gone now with a dealership part instead of the Oriely's special...
Perfectly normal, mine's the same way. Goes to about 95% at WOT.
ok, i thought so, thanks :)
