K i have a 90 bird with a 3.8na and it has trouble staring sometimes but as soon as u apply throttle it starts up right away and sometimes you have to give it gas when it starts up or it wants to stall...Could this be the TPS acting up?
Sounds more like the IAC isn't opening up enough (letting enough air into the engine) when you're starting it. By pressing the accelerator, you're opening up the throttle blade and letting air into the engine (basically doing the job of the IAC).
I'd try taking the IAC off and cleaning it out.
-Rod
I took it off and cleaned it but i forgot to put like a bit of wd-40 soo i will try that if not my buddy bought a xr7 sc and doesnt drive his lx andymore so i will get the whole throttle body assemble from him and swap it all.
correct me if im wrong, but arent the lx and sc tb assemblies slightly different?
you could just buy a new IAC. Its two bolts, a plug, a gasket and you're done.
yes i was saying he bought a SC xr7 and no longer drives his lx so i am getting the tb assemble of him since he put a new iac on in anyway
