1 - 2 of 2 Posts
if you are coming up about 1/2-1" over "hot" on the dipstick when the car is running, how much over do you think that is?
I know i put too much in, because i had no clue how much was already in the marauder TC when i filled it. I drained a bunch out (i have a drainplug) and guessed, but I'm still a bit high.
Geek w/Gearhead Complex
Leave it sit over night and check it cold (make sure its running) and see where you are on the stick. If you're still high, then drain some, start with 1/4 to 1/2 quart.
I'm assuming all other variables are null (you were on flat ground)
1 - 2 of 2 Posts
