I've searched but kinda have been able to find an answer to my exact problem.
Lately I've been having a problem with the tranny in my 95 Cougar.
When sitting at McDonalds or something, I always put it in park. Everytime I shift into drive after sitting there for however long, it takes about 5-10 seconds to shift into drive. This seems abnormally long because every other time I start it up, it shifts into drive really quick.
I've also been noticing another problem. Sometimes at stop signs, the car will be in neutral, and I must either rev the engine up, or shift into park, and then back into drive to get it to even shift out of neutral.
Recently, it's also been acting up around corners.
I take this one corner on the way to work at about 45 (country road.) I am in 3rd when going into the corner. I always let off the gas going into the corner, and then get back on it out of the corner. Lately the cars been in neutral a few times, and then all of a sudden slams into gear...hard enough to chirp the tires. It does this even if I do not get on the gas. Even if I tap the gas pedal it does it.
The car has 178,xxx miles on it. The fluid has been changed every 60,000 and I was planning on getting it done soon.
