Now my tranny is acting up (O/D light flashing and TC sound funny, intermeting clanking and idleing high
MaleWhore
Be more descriptive....o/d flashing means the tranny is throwing a code...be more descriptive of what its doing and someone will most likely have your answer...
Light is a slow but steady blink.
Have intermitten clanking from bellhousing and when running the shifter the Shifts are harsh. Have not but it back on road yet so don't know how it drives.
Also it idles near 2000RPM and wont idle down (does drop down to a more normal when in Drive/1/2)
The OD light flashing is the Tranny's way of telling you something is wrong with it.
Plus you are getting clanking noises and high idles.........and you are still driving it?
I am not sure what info. you are looking for here, but you have to get the codes scanned to find out what the OD light is trying to say.
If I were you, I wouldn't drive the car at this point.
No I have not driven it, just had it running to add fluids.
Didn't you just put a new motor in the car? I'd double check all your connections and make sure the TC nuts are tight.
