hi
my tranny slip when it shift from second to third gear only when im making a hard turn or under heavy braking
im just wondering what could do that
thx
I might be getting starved for fluid - have you checked the level? Also, starting in '96, Ford modified the tranny pan with a "dimple" in the bottom to prevent this from happening. You could put a '96 pan on yours - they're only around $20 I believe...
the fluid level seems fine to me.. well its in the middle of cold and hot is that good or?
thx for the quick reply
Not about level, it's centrifugal force.
There is not enough pan depth to keep the pickup tube under oil with hard turns.
BMan
