I'm considering to swap the 5 spd out of my '93 T-Bird for an AOD.
IS the bell housing different on the AOD for the V6 and V8 engines?
Is the transmission electronicly controlled?
Is the lockup on the convereter controlled by the Computer?
will the computer need to be swapped?
Rob
Yes
No
No
Shouldn't have to be.
But why would you want to get RID of a 5 speed?! I'll swap you my AOD for your 5 speed.
Discussion Starter · #3 ·
I was hoping that bell housings were the same because I found an AOD out of an '88 GT real cheap.
Rob
