Formerly known as lfteyechicken
ok, I have a 97 bird, and the problem resides in the fact that the car doesn't want to shift into second gear, I have to kindof feather the throttle to get it to shift, and then when I slow down or coast to a stop, the car bogs down, and right before I come to a stop the car hits back to normal (when I say hit, the car jerks mildy, not violently back to normal.) I have been told that the clutch plates are welding together and I need a rebuild. I have a mechanic friend that is going to oversee me rebuilding the tranny (Hands on learning) But I need to know what to replace. I was thinking it was the electronic shift mechanism thing, but I was told the clutch plates, any Ideas??? and what parts do I need to get to fix the problem.
While it's possible the 1-2 accumulator has gone bad, 97s should have had the better one from the factory. So that makes the most likely culprit the roller one-way intermediate clutch. Delayed 1-2 shifts, or shifts into 2nd gear with a jerk or a bang are common. And by the way, clutch plates don't weld together. Run far far away from whoever said that and don't look back. They don't know a clutch plate (or any other various items) from a hole in the ground.
ok, so this roller one way clutch thing, is that all I need to replace, what will be involved with replacing that, full rebuild, or what.
if you aren't going to rebuild it to Jerry's specs then just junk that tranny and put a new model 4r70w in there.
agreed. :zwthstpd:
