i have a 95 tbird 4.6 if i driving and put it in nuetral then back to drive it takes about 3 seconds to engage back into drive,if i hit the gas before the 3 secs it will slip into drive,is this not normal.other wise it shifts fine.the car has 62000 miles on it.thanks
Do a search For MLPS. That sounds like a common problem. Autozone calls it a nuetral start switch I believe
Sometimes they will take a little longer to engage drive when they get a few miles on them... The J-mod would most likely solve the problem. Check the first 3 tranny articles for info.
Welcome to the club! You can find just about anything for these cars here, and there is a lot of knowledge to help you out. We are kind of fans of the :search: here though, as a lot of things come up pretty often (and it'll also save from waiting for replies).
