1 - 13 of 13 Posts
I have a 95 tbird with a 4.6 the tranny is done it wont even shift into 3rd and i wana put in a 97 mark 8 tranny in it i already have the tranny What do i need to do to make it work thanks guys
Oops, I edited this because I was a dork and thought you said 98 instead of 97
The 97 transmission will only require that you swap out the TCC solenoid from your 95 transmission. Its a direct swap otherwise.
Darrin
Hey darrin... on a sid enote how hard is it to swap a 01 gt tranny into a 96 cougie? Thanks!
The 96 has different electronics so you will either have to rewire the car or swap out the internal transmission wiring harness and electronics.
You will have to swap the manual lever.
The GT transmission has an 8 tooth output shaft and the cougar has a 7 tooth. So you need to get the proper speedometer drive gear to correct for that.
Other than that, straight in
Darrin
Discussion Starter · #5 ·
is there anything else i should do to marks tranny before it goes in
Discussion Starter · #7 ·
iv been told something about needing to change the acculators is this right
Discussion Starter · #9 ·
also is there a gain to using the marks converter what do marks have for rear ends cause i picked up a mark case
To use the MK converter you will need the flexplate off of the MK engine. The converter on those cars is a smaller diameter than the one on your car. It won't bolt up unless you have the proper flexplate. IE, one from a MK, a Mustang or a Marauder. Huh, those all start with an M. Must be something there. LOL
All Mk's have an open rear end and probably have the same gear ratio that you have. The benefit is in weight savings from an all aluminum housing. And that ain't much.
Darrin
Discussion Starter · #11 · (Edited)
thanks and i do have the flex plate and what gains do i get from useing the marks converter
Discussion Starter · #12 ·
anybody
1 - 13 of 13 Posts
