Working out some kinks in my 66 project. I'm running a 331 stroker with holley sniper efi. Air conditioning w/ 02 4r70w and US shift Quick 4 (FTI 2400 street brawler lockup converter).
Finally got the car together after a few months, and I've got a couple bugs that need addressing. One of them is the overall temp of the motor when running on hot days.
It's been in the 90s with alot of humidity. I watched my motor temp reach up near 220 while stuck in traffic for about 15 min with the AC on. I'm running a 3 core champion radiator (OEM size for 66 mustang) with a spal electric fan with the trans plumbed through 6an braied lines attached to the bottom ports on the radiator.
Today when the temps started to climb, I noticed the trans temp hit up around 201. This is light cruising around. Not getting on it at all as I'm still breaking in the motor/build.
So, I had a few questions.
1. Will a trans cooler help reduce the radiator temp if I plumb it after the rad on it's way back to the trans? I would assume, yes but not much. And may gain more reduction in temp with item 2 below.
2. Can I skip the radiator all together? Car won't really be driven except for "Better weather". I plan to drive it alot, but just not in the dead of the winter. (Live near St Louis MO area in the Midwest)
3. What size trans coolor should I work on finding a home for in my 66 with either of the above scenarios? (IE with radiator, without radiator)
4. I can only mount either right in front of the AC condensor, or behind the front apron (no direct air flow down there).
