Put the tranny in from a 2000 Mustang GT(Thanks timb), only thing is the speedo is off.
What gear if any do I need to put in to fix?
I have a 3:27 gear ratio.
I had no idea the difference would be so noticeable between the two trannys....very nice :D
02 Explorer Pioneer
The mustang output shaft has more splines so you need to change speedo gears to compensate. As long as you have a 3.08 or 3.27 you can use a gear. I just looked up an email I had...you need a purple speedo gear Dan Newman can get it for you
Thanks again timb:D
I'll give Dan a call.
High-Mileage 4.6L Thrasher
I posted the output shaft differences a long time ago...guess nobody paid attention.
The Mustang uses an 8 tooth,and the Tbird uses a 7 tooth for the speedo drive gear.
JL
Must have missed it, output shaft would not have come to mind unless mentioned.
Now I know.
Thanks
