1 - 15 of 15 Posts
Hi,
I have a friend who has a 1995 Cougar with the V8.. They are telling me it is having a trans issue when it is cold. They are describing it like it might be starting to slip. I have not felt it happen the very few times Ive driven it cold. I don't think its had a fluid flush in quite awhile. I'd like to take it in and get a full flush done but am hesitating slightly, remembering all the old horror stories of once you flush it, it may grenade itself.
The car does have a EGR No flow code and a O2 sensor code that Im in process of finding a warm spot to dig into fixing it. I'm not sure if either of those could produce any similar symptoms.
Where is the best place to start??
Drop the pan and change the fluid and filter. Might think about switching over to the 96+ style and and filter if he wants to spend the money.
How many miles on the car and how long ago was the fluid done?
Honestly, no clue on either question.
Odometer stopped turning a long time ago. I am honestly not sure if its been changed since they owned it. 2008 or so.
I would skip the flush and drop the pan and change the fluid and filter. The flush might turn into one of those horror stories you mentioned! :eek:
Gotcha.
I think Ill start there. Maybe a can of the Seafoam trans tune in with it. and maybe change the filter and fluid again in 6 months.
It definitely only acts funny when its stone cold. Drives totally fine once warmed up.
That sounds like a worn pump to me, I have a van that does that and I've seen it in the past.
Let us know if the fluid/filter change helps!
Change to the deep sump pan and filter. My Cougar did the same thing until I went with the newer pan. Fluid starvation is the cause.
Where would I order a deep sump pan from?? Do you think that would fix the issue completely. Kind of on a tight budget on this one. Figure If i am gonna drop the pan for a fluid/filter change anyway. It can't hurt if the pan is reasonably priced.
New from Ford the pan and filter are less than $50 together.
I can usually get used pans pretty cheap and the filter I get cheap too. As long as I can get one I can get both shipped to you for that. Ford is strange one day you order somethign and it is $35 the next day it is $90 and a few months later it is $20. Sometimes Ford prices are impossible to beat.
Alan
Alan
Ford dealership in Perry, Florida charges 69.00 for a 4 wheel alignment. Every other place charges close to $100 around here.
Hi all,
I've yet to get a chance and experience this problem for myself, Alan, as soon as I figure out my course of action, I will let you know on that pan and filter.
Could a No Flow EGR code, possibly make the car chug or feel anything like a trans slipping a little??? Im dealing with a very rough description of the problem but I know what codes came up on my scanner.
Discussion Starter #15
Thank you Alan,
This makes me wonder because it was decribed as a bucking feeling, much worse when the car is cold... I gotta rip that EGR apart ASAP.
1 - 15 of 15 Posts
