1 - 10 of 10 Posts
The new trans is all in but I snagged teh lines while it was being aligned and bent them. Question is if anyone can get me a pic of where the liens go into the trans or just tell which one goes to the top and bottom hole(left line being drivers side)? I have a pretty good idea but just want to make sure.
-Miller
i can print off a picture out of the catalog , but i dont have a way to scan it, do you have a number i could fax one to you?
Justin,
Lets try this number:
18456251238
Its through aol and I've never used it before but its worth a shot.
-Miller
ill try in a few mintues, its actually for a 93 but should surfice for what you need. justin
it went through , let me know how it turned out.
Ok got it. I am surprised aol actually did something right. It should be all I need.
Thanks Justin,
-Bryan Miller
:thumbsup:
Justin,
If the lines get switched is there any thing I shoudl be worried about? LiKe a valve or something. I am trying to track down the source of a noise from my trans.
thanks,
-Miller
well i dont think i t will, due to the fact of its going to push the fuild thru the cooler whatever way its hooked up.
The only way that switching the lines would cause a problem, is if someone had installed a inline filter in the trans lines. If it were switched then, it would send all the crap back into the trans.
1 - 10 of 10 Posts
