hi i installed the AOD-HP kit in my trans and now when i drive it it seems to slip when taking off and when in regular drive it will go to 4200 rpms no matter what and then shift. then when in od it seems to shift sort of ok. it almost won't kick down out of 3rd. do i need to readjust the tv cable even if i didn't touch or even look at it. now if i didn't do any damage to the trans i have been even thinking of a full manual valvebody. thanks
3rd Gear Chirper
Um, the AOD-HP kit required you to remove the valvebody, correct? Did you properly torque the bolts back to specs when you reinstalled it? And have you gone back into the tranny a few thousand miles after the install and re-torqued the VB bolts? I mis-torqued mine and had it would only hold third gear for about .5 second and not at all when at WOT, it just went 1-2-4. Also, it would neutral out on takeoff. Retightening the VB bolts cured it.
